luongo27
Something a little bit different, thought I would show you my recent build.
Components:
Some of the negatives are that the reserator fan is a little loud, dust will become a problem over time and the 200mm max graphics card length is more like 190mm. Which I found out to my cost, having had to cut off a bit of the cards plastic shroud.
Let me know what you think and suggest any ideas of how I could improve it.
Anyway here's some photos:
Components:
- AMD Athlon 760K
- Gigabyte F2A88XN-WIFI AMD A88X
- Powercolor R9 270
- Geil Black Dragon 16GB 1600MHz
- Zalman Reserator 3 MAX
- Coolermaster V450S Power Supply
- 60GB OCZ, 240GB Crucial SSD's
- Corsair SP120 fan
