So called tech departments - are they any good in the face of adversity?
Here's a direct cut n paste from my XFX tech support ticket... A friend of mine asked about the quality of support so I made up this fictional issue about DVI/HDMI EDID resolution issues... Their complete lack of understanding about their products is quite astonishing...
[ 1/7/2010 3:16:44 PM] Using a DVI HDMI adapter and HDMI cable into my monitor, I get no picture during POST (or anything `text mode` pre-windows). Using another monitor, I am able to see that the card defaults to 1280x720@50Hz. Unfortunately, the monitor I want to use doesn`t have this in its EDID. How can I reflash the GTX to use something sensible like 1024x768@60Hz at POST?
[SHAUN_T 1/7/2010 3:20:09 PM] Hi Rick, thanks for your message, please edit your XFX profile by registering your graphics cards serial number. Im afraid this is down to the monitor, not the graphics card. So with the other monitor that you tried, did you have these issues or did it all work without any issues? Kind regards, Shaun.
[ 1/7/2010 11:34:08 PM] I don`t know where the serial number is. The other monitor was connected via VGA which my monitor does not have. Over DVI, and over HDMI it outputs 1280x720@50Hz which this monitor displays as `mode not supported` during the BIOS/POST/text-mode phase of boot-up. How can I flash the bios to tell the card to output another resolution/frequency over a digital-out during the BIOS/POST/text-mode phase?
[SHAUN_T 1/8/2010 10:25:13 AM] Hi Rick, thanks for the quick response and extra information. There are no BIOS updates available for your graphics card Im afraid. We recommend contacting your monitor manufacturer to see if they can help out with this. Kind regards, Shaun.
[ 1/8/2010 12:36:35 PM] Just tell me what bytes I need to edit in the BIOS and I`ll do it myself. How exactly would a monitor manufacture be able to help with the slightly-non-standard output resolution of a graphics card? All I need if for you to say `change xyz bytes to xyz` and it`ll output 60Hz and reflash and I`m happy... I can send you my monitor`s EDID if it will help you?
[PAULV 1/11/2010 11:17:21 AM] Hi, thanks for your message and for letting us know. The card does not default to any specific resolution, this depends on the drivers, but during POST the card will use a BIOS standard display implemented. What you need here is an EDID update, which only the monitor manufacturer can supply, im afraid we are not in a position to state which specific Bytes you need to change as we only support XFX cards, again this is info you will need to source from the monitor manufacturer. Hope all goes well, however if any queries or problems please keep us posted. Kind regards Paul
[ 1/11/2010 7:15:54 PM] Drivers don`t come into it. I am on about POSTing. Like way before the OS loads. Do you have a clue what POSTing even is? Since when has 1280x720@50hz been a standard for displaying text mode? (And why does it output 1024x768 over VGA during the same period?) Please give me the *exact* timing information then for my *XFX* card`s output then over a digital connection and I will flash my monitor`s EDID. I`d really rather just flash the graphics card and tell it to use VESA timings during POST, and not my £1,000 TV. I need to knnow the active pixels, front porch, sync width, back porch, blanking and total pixels as well as scan rates (obviously I need horizontal and vertical for all those). And this IS an XFX card - I wouldn`t be writing here if it wasn`t. A gigabyte card (same GPU, slightly lower clocks) puts out 800x600 so it can be done. NOWHERE IN THE DOCUMENTATION FOR THIS *XFX* CARD SAYS MY TELLY HAS TO DO 1280X720@50Hz TO DO TEXT MODE. I can`t even install windows (text mode obviously) on that machine without buying a new monitor. Cheaper for me to bin this XFX and go and buy something proper. With tech support who actually have a clue and aren`t simply reading from a script trying to fob you off at every opportunity.
[JAMES 1/13/2010 3:27:18 PM] Hi, thanks for your message, we do not have tis documentation at the moment Rick, but probably the quickets way to get at least most of this info would be to download the `powerstrip` application fro a site like guru3D.com. This has advanced information on monitor and video display hardware and will have most of the details you mentioned. kind regards, James
[ 1/14/2010 11:56:36 AM] How do you propose I get into powerstrip when I can`t see the screen to install windows? Perhaps if you actually read my messages we`d get further. There were 3 spelling mistakes in your last reply by the way. You`ve told me to update my EDID which I will do (had to buy a lead for £80.00!) and now you`re saying you don`t have the data needed for me to update it. So far I have wasted £280.00 (card, HDMI lead, and now EDID flash lead) on your stupid company. I need the timing data so I can flash the EDID. All you need to do is fire up a similar card for me in windows (connected to a monitor or TV by HDMI) - open the nvidia control panel, set your PC to 1280x720@50hz, go to custom resolutions and tell me *all* the numbers that are written in there. IT`S NOT HARD. Now please help me and stop trying to fob me off.
[JAMES 1/14/2010 1:07:11 PM] Hi, thanks for your message, and also for the spelling critique. I`ll try to do better next time. We will get this info for you as soon as we have a matching working card. Regards, James.
[ 1/18/2010 11:32:15 AM] OK... I was just getting so stressed about this. All I need is for someone to get to the 1280x720@50hz res, AND IT MUST BE PLUGGED IN VIA HDMI (because the numbers are different using a VGA adapter), get into custom res, and pretend they want to create a new res, and the numbers are all in there. By default it only shows horiz, vert, and refresh - you have to click the little box that makes that dialogue expand to show all the numbers about porches and sync widths. I will wait for your reply when you have the matching card. My card is the 192core, 640mhz one. And while I am on to you... when will you start selling the Fermi based cards... I am desperate to go DX11 but can`t stand ATI/AMD stuff... Please don`t reply till you have the numbers I need... Because this ticket will go `idle` and I don`t want that to happen...
[TONY 1/20/2010 4:57:35 PM] HI, modern implementation of the digital visual interface relies on EDID information from the display hardware. If not detected, you will not be able to setup the display properly. I`d advise to check for a firmware update for the monitor/tv and please let us know if it helps. BTW do you have any problems registereing the serial number? Thanks Tony
[ 1/20/2010 6:42:20 PM] Tony, please go back and read the whole `thread`...and DON`T REPLY TILL JAMES HAS THE NUMBERS HE`S GETTING FOR ME - I DON`T WANT THIS TICKET TO SIT IDLE... Lord knows where the serial number is...i bought this card from Scan, Bolton, UK if that helps...
[TONY 1/21/2010 3:19:26 PM] HI, serial number is on the product label on the card and on the box, e.g. J1H918532. Thanks Tony
[ 1/21/2010 3:27:09 PM] OK. I can`t pull the card out my machine to see it. My bios will reset to default if I do. And if you read the whole thread - you`ll see why I can`t do this till I get the numbers I`m waiting for. FOR THE THIRD TIME - DON`T REPLY TO THIS UNTIL EITHER YOU OR JAMES HAS THE NUMBERS I NEED - I DON`T WANT THIS TICKET TO SIT `IDLE`. YOU LOT ARE BEGINNING TO IRRITATE ME NOW.
[JAMES 1/21/2010 3:29:09 PM] Hi, thanks for your message, we will need the serial number to be able to check this properly Rick, you can get it from the outside of the retail box. kind regards, James
[ 1/21/2010 3:38:41 PM] After I spoke to the retailer about a refund and he said no as the card is working I recycled the box and no longer have it. James - can only you deal with my problem, please. The other guy seems like an idiot. As soon as I can get a picture on my screen with the timing numbers you`re finding - I will pull the card out and send you the serial number. The card is a GX-260N-ADDU. A geforce 260, 192 cores, 640mhz core, your XXX version. Again, DON`T REPLY TILL YOU`VE GOT ME THE NUMBERS - I DON`T WANT THE TICKET TO SIT IDLE! I will be straight back to you with the serial the *minute* you get me the timing numbers.
[JAMES 1/22/2010 3:42:32 PM] Hi Rick, on GTX260 via DVI-HDMI at 1280x720@50hz on Automatic timings and progressive scan gives the following settings: Active Pixels - Horiz - 1280 Verti - 720 Front porch Horiz - 440 vert - 5 Sync Width Horiz - 40 Vert - 5 Total pixels horiz - 1980 verti - 750 Polarity Horiz - positive Vertic - positive Refresh rate Horiz - 37.50 Vertic - 50.00 Total Pixels - 74.2500mhz good luck kind regards, james This is all the info - there is no back porch info
[ 1/22/2010 5:05:53 PM] Stunning. Brilliant. The serial number is J8T062553. The card says it is a GX-260N-ADD9 so sorry for that. I`ve flashed over those numbers to my monitor`s EDID and I was up and running straight away. I could calculate the back porch from your figures myself. Windows 7 64 is now installed and working perfectly. It`s a pity it took over 2 weeks but it`s working now. SHAUN_T, PAULV and TONY suck. You rock.
[TONY 1/22/2010 5:21:07 PM] hi, glad to hear you did resolve, but we do not appreaciate comments like `suck` and `idiot`. ticket closed. Tony
[ 1/22/2010 6:42:15 PM] No problem. It`s still true though. Yes, feel free to close the ticket.
...still reading? lol. So, to sum up... they've got cracking products - but no idea on how they work. ...and they haven't even closed the ticket yet!
...and if anyone needs help doing EDID overrides, monitor resolution issues...give me a bell - I'd hate for someone to actually have this problem. 86sixsix.
