Dicehunter
Resident Newb
So I changed out my Rampage V Extreme for the Sabertooth simply because I prefer the looks of it.
Now on my RVE I used adaptive voltage with 1.28v on my 5930K for my 4.60GHz overclock with a base clock of 100, Cache at 3000MHz and my memory at it's rated speed of 3000MHz.
I tried the same settings on the Sabertooth and for some odd reason it will not allow me to have anything higher than 2400MHz on the memory without it not being able to boot.
Now if I use manual voltage so it's set to 1.28v all the time with a base clock of 125 and a multi of 36 then it all works but then this puts my idle temps up by about 7'c which isn't something I want.
For some reason I cannot get 3000MHz on my memory with adaptive CPU voltage and I have no clue why.
Any input would be appreciated
