elite_modder
So thought I would post my rig, came here before building for some advice and guidance with choosing parts.
It's now almost complete, plan to possibly add a second GPU and double the memory. That wont be anytime soon though as I have no money
At the moment the 3GB GTX 780 has been taken out, to be sent back to EVGA through the Step Up program and I will be getting the same card back just with 6GB of memory all for £26, result
This does mean I'm having to use a Radeon HD 4350 1GB as it was the only thing I had spare
, cant even play trials HD without turning the graphics down all the way.
The specs are:
Let me know what you think, is their anything you would have done different or added extra.
Thanks, to Feronix for the advice pre-build.
The specs are:
- CM Storm Trooper Windowed Case
- Rampage IV Extreme Black Edition X79 Mobo
- 4930K 3.40GHz @ 4.2GHz
- EVGA GeForce GTX 780 3GB ACX Superclock
- Vengeance Pro Silver 16GB (2x8G 1866MHz)
- Samsung 120GB SSD 840 EVO
- WD Caviar Black 2TB
- Asus 24x DVD-RW
- SuperFlower Leadex Platinum 1000W PSU
- XSPC Raystorm 750 EX240 Kit
- Windows 7 Pro 64-Bit
- BitFenix Spectre PRO 120mm Fan Green LED
- BitFenix Spectre PRO 140mm Fan Green LED
