WTH EK strix ng
blair
Hello all bout a strix 1080 and a ek waterblock and backplate. Water block fits fine but the backplate tell you to use m2.5x7 scores to attack it the backplate doesn't come with any screws and the waterblock comes with 6mm long scores which don't bite wtf am I suppose to do ek. Can't even mount this because you don't provide the correct screws.
Have you send them an email. It might be a mistake on their side
ive had blocks come with double the amount of screws so its very possible the opposite can happen. give them an email and they will help you out. ive had dealings with them in the past and they are good guys.
Sorry about that :(
Open a ticket on our website and we'll send you the missing hardware.
Link for the ticket : https://ekwb.zendesk.com/hc/en-us/requests/new
My God I hate the auto correct. Found some screws from previous bits and bobs and managed to mount them all now.
Might be a bit late but I had the same issue. Not saying you haven't, but make sure you open both ends of the backplates box. I thought I didn't have mine but they were stored in a very small compartment at one end of the box. Might be the same case, who knows? Worth a try though.
