Would it be Worth It?
welshman1001
I'm thinking about water cooling my 600T with AMD 8120 CPU. I'm running the stock CPU Fan and get an average of 60-65C when playing a game. Would it be worth upgrading to water cooling? If so should I use a sealed unit like H100i or a custom build system? (I haven't yet overclocked but I am wanting to)
a loop in a 600t doesn't make a whole lot of sense, especially not for someone who is new to overclocking. the h100i will fully suit your needs, way less work and you will most likely not go to areas where a custom loop is needed. also a custom loop in that case wouldn't differ much from the h100i anyways, there isn't a whole lot of room.
This. Keep it simple for now.
