WMP in Vista not showing
Rastalovich
Vista been up and running on the pc in question for about 2 days full.
U select a file to play, music or movie, and it plays but wmp doesn`t show itself. (so u see no movie, but u can hear it like the music)
Click on the wmp quick launch thing, and it will show itself - and show what it was u selected to play. Close it and it hides away, still playing the media!
It`s not like it`s starting minimized, cos u can minimize it after using quick launch and re-maximize etc.
If a codec is used, u stop the media, close wmp and the codec refs are still in the tray.
Any ideas ? This is Ultimate with mediacenter and codecs installed for the 4 popular movie types.
Worked fine til about the 2nd day.
probably a MS feature ..
Try deleting the application data folder for WMP
failing that Control panel > Programs > add remove components > remove WMP then reinstall
Yeah the package as a whole I`m thinking. I went by the route of component removal, but it wasn`t on the list. Not in the program control thing either. Went to re-install without removing it and it said the version I have is too new. Could see if it`d force in, dunno.
Weird thing is I run the wmpcfg.exe (which I think is the configuration part of it) and it shows in processes, but doesn`t appear.
Not a good start to using Vista again, feels awful.
Just googled u cant actually remove it *sign -- stoopid fucin M$*
Try going 2 safe mode loading WMP and removing all add/plug ins from WMP
oh and delete the userz/applicationdata/local + roaming/ media player folders
*show hidden folders*
.. and it`s got some kind of wmp-network thing and other involved services.
Pretty spooky when u boot a 2nd pc and it exclaims - "Windows media player is available on another pc" - or similar.
Some1 would have uninstalled it at some point.
I`ve got a drive image, so I could try putting that back on and see if it falls down again.
Fudge sake, I`ve only had it on for a few days.
Just got in and ran wmp after restarting the pc and it ran fine.
Difference I notice is I haven`t run F@H smp yet.
Could be something conflicting there.
