Feronix
In fact, it won't do anything.
Right, so around 3 months ago I built my sister a decent system with a Haswell i3 on some ASRock motherboard (B85), 4GB Kingston Fury RAM and a WD Caviar Blue. Cause my dad couldn't be arsed to make an ethernet cable go up to her room (attic) I also threw in a WDN-4800.
Friday she said that Windows would suddenly no longer start up because of a hardware change. I found this weird so I took a look and upon starting the PC I was greeted with this screen:
Tried both options (obviously) but:
Repair: It starts "Loading Windows Files" which it does within 2 seconds. Then the screen goes black and after a few minutes a cursor appears that I can move around. But then nothing happens.
Normally: We get the neat little Windows 7 boot animation, then again the screen just goes black and after a few minutes the computer reboots itself only to end up at the same screen as in the first image.
I booted into the Bios and set everything back to defaults (even tried a few other things) but none of that seemed to help at all.
I then started mashing F8 while booting to get this, slightly longer, list of boot options.
None of these seemed to help. I cannot even boot into safe mode, however when I do pick any of the safe mode options it does get stuck at this point:
I Googled that for a bit but all of the solutions seem to require you to boot into Windows, for example to do registry edits and such. Thing is; we can't get anywhere near the OS itself.
After about two hours of staring at black screens I decided to re install Windows. Was planning to install a new version on top of it, allow her to boot into that to back up her files and then format the entire drive and start fresh.
All she had however, was a Windows 7 disc and we didn't not have a 4GB+ USB lying around to move the files onto that so disc it was. But her computer does not have a DVD burner. No biggy, I've got an external USB one for cases exactly like this.
Put the DVD in the external drive and plugged it into the computer. Booted into the bios and set the DVD drive as Boot Priority #1 and just to be sure I removed the DVD from the boot list entirely for the time being (picked the 'None' option for boot option #2).
Did the whole "Windows is loading files" thing again, this time reading them off the DVD so taking a good 30 seconds to do so. Then the screen went black again....
So basically; I cannot boot into the current OS install, but I can't install a new one either. What the fuck is going on?
Any help would be much appreciated cause honestly the best thing I can come up with right now is buying a new HDD and start fresh... Is the HDD maybe simply broken?
Thanks in advance guys!
