I'm having a problem with my LG BH08LS20 BD-R drive.
When I try to read UDF discs (i.e. standard "file and folder" structure), Windows reports an unrecognized file system. Nero can write UDF Blu-Rays fine, and VLC can read DVD movies fine, but reading of UDF discs of either type is a no-go. The drive works properly in my father's computer, by the way, and is running the latest firmware, and I have the latest drivers on mine. I've tried two different SATA ports and two different cables.
Only changes I've made are an installation of Isobuster (which I since uninstalled) and a recent Windows update. I strongly suspect that my W7 UDF reader is damaged, or there is a conflict - does this sound plausible? If so, does anybody have any ideas on how to restore the native Windows UDF, or replace it?
Please help me ASAP if you are able - I really don't want to do a re-install of Windows if I can avoid it
