Well i have been contemplating cutting a window into my Fractal R3 for some time now and finally decided to go ahead with it. I'm thinking a nice light smoked plexi-glass with some leds inside to show everything off, I'm going to get my buddy to build me led system to fit the case so every led and wire will be hidden. the top of my new NH-D14 will be painted flat white along with my 6970's should to really reflect all the light it can. if i can find some white 3m di-noc film to use instead i would rather go that way. and lastly i will be sanding and re-painting my orange front of the case to match the inside. and being that this computer also acts as a home server rather than just a gaming pc i am stuck having to leave the HDD cages in the case, i would love to take them out but cant.
PLANS:
1 square window that does not show the PSU, HDD's, or BR drive.
1 cut white piece of plexi to hide cables and PSU
1 custon led lighting kit, Probably blue or red.
1 repainted front door.
here is what the case looks like now,
Thanks For Looking.
PLANS:
Thanks For Looking.
