win7 64bit problem
jaba453
hey guys,
right here's the problem, i have win7 enterprise (64bit) and i have 4GB of ram but its only picking up 3.24 as a userable amount , any idea's ???
Try this, type msconfig in the start menu, press return when it shows up in the menu, go to the boot tab > advanced options and check the max memory box, if it does not show 4096mb increase it till it does. You might need to reboot to see if it has worked.
