Right gonna quote direct off another post I have going but to see if anyone else can help here cos I am at a loss....
This all started yesterday and is happening again todayIt all started this morning (early this morning about 5am); I had shut my machine down as I normally would last night (switch PSU off on PC as flashing USB light cable is annoying!) but at 5am I heard my compressor start up...
I sat upright in bed and looked at it and it said MACH II Activated but then after 20secs it went back to idle...
I didn't think anything of it at the time adn went back to sleep.
Wake up this morning and decided to swap my PCP+C 510Dlx in (cheers marci! ) so I went about swapping the Tagan to the new one and it looked great and lot easier to cable in than the Tagan (Plus I can now screw PSU all the way back as couldn't before due to 120.2 rad and Tagan depth). Go to power up and it takes an age to pull down to 0c.....
...hmmmm I thought tres strange so I let it continue and it got to -14c and came up with a Too slow error. I switch off the prommi and pc leave it for 10mins and restart. This time she pulls down to -25c in next to no time, almost too quickly! Hits -40c and boots up. Excellent check rails in BIOS and boot into windows...
after a couple of minutes temps rise to 0c it alarms and then shuts down...
OH no you can imagine what I thought when I tried to pull it up to boot the temps where rising not falling....(you can smell my fear that this point)![]()
So i have a listen and can hear what I thought was leaking gas... Nooooooo so I try one last time and she starts to pull down quickly to -25c....then -40c and boots....gets into windows and it comes up as too hot again
i am really panicking at this point thinking I must have knocked the house and torn the thermal bus!!!![]()
As the temp was jumping between -49c and 80c and flashing sensor uffa error on display I started to think hmmmmm maybe then its a boot loader issue.... This would explain the dodgy compressor start and why having so many errors....
So out comes my mums new PC and I open her up and connect the USB and power header, install the software and flash to 821 bootloader software. Flash is successful and I restart the prommi and attach it back up.
Let it sit in BIOS to check temps and after 10mins of sitting at -53c and -27c (well -17c but DFI reads 10c low ) in BIOS I boot it her up...
Well I am now sitting here for like 20mins and no problems. I have been running F@H (with prommi panel off) and Evap is -42c with fans just above normal and CPU at -10c.
So I suppose the moral of the story is that there is no need to panic when these things go wrong and to logically go through each step to try and resolve the issues. Its not difficult and took me hour and a half to resolve the issue and get my machine back up and running
How glad am I I haven't torn the thermal bus? About this big!
Hope this helps someone how may be experiencing similar problems
What do you guys think? Is she properly stuffed?I switched machine off last night after a days successful running with temps being great (Evap at -42c cpu @ -1c --> 1c) but this morning flick everything back on at the switch and am greeted by a prommi trying to start itself and coming up with SENSOR FAIL Sensor UFA
I have made a small clip of it in action on my camera...
Uploading now
I think I am gonna cry. What can be done?
