Which windows is best for benching?
Thanh55
I join our benching team and very liked it. I just wonder which windows you guys use to bench? I got feeling vista have too many thing run @ back ground and it like slow down your bench. Many thanks for your help.;)
TinyXP is pretty good.
I read a little snippet that 7 was at least better than vista though.
Another noob question then I don't have any pc run XP so can I use nLite to strip doown XP from its disk? Any change to strip sown vista anyway. Many thanks for your help. ;)
I have some distant memory in the back of my mind of using nLite on a laptop that had an OEM i386 folder on it for as XP install cd.
I have lots of memories tho see.
Many thanks for your repy but my English very poor so I'm not quite understand what did you mean?! It is mean I have to instal XP on a pc and run nLite from there? Thank you very mcuh for your patient:worship:
a 32-bit OS can indeed only use 3.2~3.5 GB of memory.
but if you only have 4Gb installed it is not needed to use a 64-bit OS
cus the space of memory that will come available will be filled with bigger variables from the 64-bit OS.
on the other hand if you have 6Gb (triple channel) it is very recommended to use a 64-bit OS
XP with least amount of drivers will do good. Vista will eat 1-2k of your 3DMark scores so I'm guessing it does a similiar (in terms of percent) amount of damage to your benchies :)
