Which water block?
LiamTheBoss
Hi there,
I am upgrading my loop and am torn between the ek supremecy plexi and the xspc raystorm. Which one would you go with? It will be cooling a 3570k. Or should I go with a cheaper block all together like the ek supreme?
Any suggestions will be much apppreciated.
I have a raystorm it's a very nice looking block, the black plate will detach if you desperately need to customise it. It's very well built :) easy to fit.. that's just my 2 cents
EK did used to be epic but after the nickel saga and now the god awful designs I dont think Id willingly spend my own money on their kit atm.
Maybe when they bring out the next gen Id have a look but there is loads of other brands out there now, why risk it.
Are you refering to EK's latest GPU blocks? The blocky square ones? Have to admit I don't really like those either
id go Raystorm for the CPU. many options use go when using the Raystorm.
color LED acrylic, full metal retention mount, full-on chrome plating. looks to
kill with would be the Raystorm.
airdeano
