Yes everything should fit or you will surely find some place for it to fit. Start assembling it and take some pictures so you can show off on the forum
 probably end up looking like a go kart looool
probably end up looking like a go kart loooolhaha will do mate!cheers.as soon as the rest has arrived i went against the 580 hydro copper= £600+ whent with 2 x 570sc,s me m8 just got em cheap so im gettin em too gonna stick koolance blocks on em both.probably assemble next week pics will follow.step by stepprobably end up looking like a go kart looool
hi my xspc d5 res came today with my swiftech d5 655 pump-also recieved my xspc rx240 rad.can some one tell me what bits ill need for my cpu plus gpu do i need compression fittings if so how many/size-also any other bits ill need apart from tubing.cheers
and zip ties.
really what you use to connect everything is up to you, and how much you want to spend on a build. Compression fittings add up on the cost very quickly, where barbs are relatively cheap and easy to come by. Personally I'm going with compression fittings, mostly because I like they way they look.
Also: Larger hose = more flow = better cooling... to a point.
