T Thanh55 New member Sep 29, 2008 #1 Hi Experts I got Asus P5K-VM board, I like to change the NB heat sink but I not seen NB heat sink like this: [/IMG] Its doesn't have 2 holes like others. Many thanks for your help.
T !TIMMY! New member Sep 29, 2008 #2 The Thermalright range will do both holes and clips, just depends if it will physically fit with other components in ur case.
