Which Motherboard?
nathan
I think i'm going to be building a HTPC soon, i've found a case i like, it's the antec fusion. It will only support a micro ATX motherboard. I'd like to use a core 2 duo, sata300 raid etc.
Does anyone have any good recommendations?
ta
Couple more questions. Is there a matx motherboard that supports crossfire or sli?
I'm looking at the X1950pro as its not to expensive, does anyone know how much hot these run, it really hot could you suggest another card thats runs cooler. (need to components to run as cool as possible as its for a HTPC)
thanks for your help!
Biostar make AWESOME mATX boards that are mad overclockable. Check out the Tforce board for C2D, I'm sure it probably pwns.
