Which mini atx mobo would you reccomend?
BlueScreen
I am trying to put together a mini atx PC however I am not exatly sure what mobo to pick up. I've found MSI H61I-E35 (B3) to fit my needs (more or less). What I don't like about it howevr is lack of dvi-d connector.
Do you happen to know any mini atx mobos (socket 1155) worth recommending? Cheaper ones of course, as his pc is going to be for surfing web mostly.
For a pc that's mostly used for surfing and not for gaming or ocing, any cheap board will do the job, just make sure that it's compatible with the other parts and offers the features you need.
I'd recommend that you only buy boards from Asus, MSI or Gigabyte.
If you're not looking to get the highest of performances and overclocking out of it, any cheap good branded motherboard should do the trick. You have to make sure you read the specifications and make sure it has everything you need ( DVI-D port ).
