NeverBackDown
AMD Enthusiast
Not sure who you are talking to but I don't want to be blunt but don't sound like a know it all?
Also you are contradicting yourself here.
You say its meant to get the cleanest sound possible. Ironically that's exactly what "audiophiles" aim to do. That word btw is just gross and has so much negativity to it and misinformation.
Getting the cleanest sound is exactly what a DAC is for.
Also in regards to your recommendations for gear of course it's going to beat anything they have. The DAC alone is more than most entire setups. I would hope at least a $3000 setup would be better than anything less. It's a backwards argument. In addition not everybody cares for original recordings because it may sound bad to some people or usually it's poorly mastered. I know people who like Jazz music complain about this a lot.
In regards to your summary, if you were talking to me I didn't say that was wrong. I always recommend external. As most people have actually with the Fiio e10k.
You might not need it but using an AMP can still improve the quality even if your current setup is capable of it. Some headphones just like power. Like high end Beyers for example excel with extra power.
That's a pretty bad advice tip honestly. Not everybody is after professional grade gear. You don't need an audiophile either to tell you what's good or not. Although they would probably give better advice anyway as they are more in line with the actual products 99% of people would be looking at.
No one here is an audiophile yet we recommended a Fiio E10k. You didn't need to be a pro for that either. It's a good quality cheap unit. It's very popular for a reason.
