which gtx 670 grathic card should i buy
is there any point of me getting this ZOTAC GeForce® GTX 670 4GB
if i am only running 1 AOC e2343F 23" LED-Backlit Monitor ?
ok what about thease
PNY NVIDIA PCI-E GTX670 XLR8 edition 2GB GDDR5
MSI NVIDIA GeForce GTX 670 (2048 MB) (N670GTX-PM2D2GD5/OC) overclocked edition
or what about a 660ti ?
So we suggest graphics cards and you don't even consider them? When two people with over 2000 posts tell you what 3 graphics cards you should go for you know they are the 3 to go for and as I said after that it is just down to the one that is cheapest or looks nicest
right ok so you say only go for those no others yer i and i would of fort 4gb would of been better than 2
Gigabyte windforce FTW. Good choice. Doesn't OC as well as the ASUS but it's alot quieter and looks awesome. :D
right ok well i am on ebay looking at some as im not buying new and there is a
Point of View GeForce GTX 680 (2048 MB) Graphics Card would this not be better:confused:
Just stick with the 670. There's about 5% between the 670 and 680 at best really.
Also, the Gigabyte will be quieter - much quieter
right ok well i dont think i will over clock it alot as i dont like putting to much strain on them so that one no matter what i do get that one ???????
:mellow:
