Which graphics card?
da2ca
I have been looking for a new graphics card for a while now. My budget was origanaly £50-£60ish for a second hand one.
The thing is i use the 32” TV as a monitor so i’m not sure what i will need, Will the 512mb be better than the 256mb?
At the moment i have seen 2 cards that sound interesting but need some advice if this is the right option or is there something better for the money i can get?
1; ATI Radeon HD 3850 256MB, new for £85
2; X1800XT 512mb w/ Accelero X2 cooler Second hand £45
3; X1900 XTX 512mb w/thermalright HR-03 heatsink with a noctua fan S/H £75
Any help is appreciated.
Dave.
_________________
the 3850 is a great card, my brother just got one for his rig and it performs really nicely.
As a tv isnt a high resolution, the bigger memory wont have a perticularly great influence on performance, but if it fits your budget it may be worth it.
Have you looked at the nvidia 8800gt 256mb from scan? its just over £100 and would really pack a punch.
Will the new 256mb card be ok on the 32" tv or will the older 512mb be better?
Does the extra ram help on a big screen?
Thanks
yea the 1st option is by far the best it should be fine on your tv tvs dont use a very high resolution so you shouldnt have any problems
it helps on a big screen in the sense of a lot of pixels, but since it is a tv, the pixel count is quite low so a 256mb card will do fine...
thats a wierd reso for a 22", is it widesreen?
It should be ok for that as well ;) the 3850 will own the other cards, and if youre that worrried about mem get the 512mb verision
Yes it is widescreen. Its another £40 for the 512mb version and i cant afford that. :(
With the 256MB version for gaming you will no doubt have to drop down from the native resolution but for general computer usage it will be fine.
