Which cases w. 120 mm fans for Mach II?
The new Lian Li series
PC7 Plus SE has front and back 120mm fans but no removable mobo tray
PC60 plus has front 120mm and rear 80mm but removable mobo tray.
pc60 plus is your bets option matey due to be right size to sit on mach 2 but im sure there is a pc60 plus with rear 120mm fan
Phil
I like the extra depth the server cases provide - the Lian Li range all fit as regards width so it's only really the overhang at the rear that puts some people off - me? I just dont look at the back and you'll be more than satisfied with the extra room inside to work with ~(look at for my revised rig shortly).
Mav
Thanks a lot :)
I'll take a look at the Lian Li cases.
I'm going to use a DFI NF4 Ultra-D and a Opteron 146 Cabye FPBW.
Will the 754/939/940 CPU kit fit on DFI NF4 Ultra-D?
It seems to me, that there's very little room around the CPU socket on MB.
I have an Antec SLK3000-B (w. 120mm fans) case here beside me.
I wonder if I could make it fit the Mach II.
maverik-sg1: Do you have a direct link for your revised rig?
Thats a PC70/75 server case mate
yhst-15623121986395_1872_11162694
name='justin' said:
mav did you mod your mach kit so you could remove the chip without taking out the mobo?
Sure did.
The Case is a PC70 server case, replaced by the PC7 which is exaclty the same but has the 120mm inlet fan.
Mav
maverik-sg1: Sorry to hear your have to RMA your Expert board.
I hope ECT will make it easier to change CPU in the future?
What's the insulation material Mach II use for the succession line?
