Surfie
Hi all!
I'm thinking of switching cases for dsv now , as i am not 100% happy with the internal layout of the Phantom 550 (it is ridiculous on my desk. So big!).
The trouble is , i want all of the performance, in a smaller (and better looking) case.
I have narrowed it down to two options. The fractal define s and the nzxt h440.
What is going in?
Asus rampage iv formula
32gb RAM
Custom water loop
Gtx 680 (water cooled)
Xspc photon170 with pump.
2 x 60mm thick rads (push only). 240mm and 360mm.
4 hdds (3xssd, 1 mechanical)
I am leaning towards the fractal, but am not sure that everything will fit. Also the nzxt extra features (power supply shroud and lighting) are attractive to me, but it is also a bigger case.
Anyone who has a similar setup able to confirm that all will fit ok? Otherwise, so you have an opinion? Which do you prefer, and why?
What is going in?
32gb RAM
Custom water loop
