GavX,
Wow thanks,
This seems ideal.
Your right about it being more fun, first rule of being a man, the more options and the more meddeling and tinkering required the better.
Example, which one of these would you have;
Pre built pc overclocked to something amazing, a true gaming pc fine tuned to the highest spec.
or
All the same parts but it would you would have to build it and tune it yourself for 3 months before getting the same quality.
I might not have got my point across to well but you get the idea.
Thanks again,
Pompalop
