What should my next upgrades be?
KapteinFruit
So I'm thinking of getting an HAF x, but I'd like to have as much input about my choices as possible.
So do you guys think the HAF X will be a good choice? Would you recommend something else?
Should I get an SSD after I've gotten the HAF X? Or should I just let my PC be slow and maybe add a second graphics card instead?
Should I get 4GB extra Mushkin Redline so I got a total of 8GB? I do some video work and image stuff. (Haven't received the first RAM kit yet.)
Should I get those braided extension cables to make my PC look very good? If so should I get it before the SSD/graphics card?
And is there anything you guys would recommend me to get? What would you recommend me not to get?
I know my threads have been bad threads for the most part, but I'm getting used to the forums and getting to know the people here so bear with me for a couple of weeks.
Here's my current specs:
Intel Core i5-750 @ 4,0GHz. All cores below 67c. And 67c was a peak temp. It's usually 65-66c. Noctua NH-D14.
2GB Crucial 1608MHz RAM. Soon to get 4GB Mushkin Redline 1600MHz. They just have to arrive at my brothers place.
XFX ATI HD 5870. 900MHz & 1300MHz.
500GB Seagate Barracuda.
Cooler Mater HAF 922.
Enermax Revolution 85+ 1250W.
EVGA Classified 200.
Asus Xonar Essence STX.
Post some pics fella, alot of what you are asking about is asthetics...
The 922 is a good case, Im really not a fan of the HAF-X's looks so Id be tempted to say put the money into kit rather than making needless upgrades.
I don't have the transfer cable for my W995 so I can't post pics. I got some old pics back when I used an AMD Phenom II X3 720, though. I could post that, but I'm not sure how that would help. Want me to post them? I'll take a quick look for the transfer cable too. And I really hate my HAF 922 now. And it's scratched which really bothers me.
looks like you have a nice system already
isn't the HAF X very similar?
It kind of is, but at the same time not. The HAF X got some great cable management while the HAF 922 got some very bad cable management. The HAF X is black inside, the HAF 922 is bare aluminium. The HAF X is much bigger. The 922 is by all means big too, but not as big. I hate the mesh on the side of the 922. All of those small things make me dislike the case. I do really like the ATCS 840 and it seems as if it's a very beloved case here on OC3D, but it's bare aluminium on the inside as well and it doesn't have great cable management. If there was a case with good cable management, a sleeker look and as cold as the HAF X I'd chose that one over the HAF X, but the closest thing to that is the 800D/700D and they're both too hot for good air cooling.
