smudger1767
Hi all,
As the title says I'm looking for some recomendations for a new PSU for my new build. Not sure whether to go normal, SEMI MODULAR or full modular. It seems after doing some research into the matter that if you can spare the cash the fully modular ones are the best.
As I have splashed out on a top CoolerMaster Cosmos Ultra Case, but I will be keeping to AMD boards.
I will be starting with a single GPU but may want to add another one at a latter time.
So really not sure to go full or semi modular, is the question I'm asking.
Also the output and some makes would be nice, but I do like the Corsair HX range.
I have £150 to spend.
Regards
Paul
Regards
Paul
