What is the difference?
Antony1995
Hello everyone,
Been looking at hard drives and quite like the WD Black drives I'm just a little confused what the difference is between these two:
WD1002FAEX: http://uk.pcpartpicker.com/part/western-digital-internal-hard-drive-wd1002faex
WD1003FZEX: http://uk.pcpartpicker.com/part/western-digital-internal-hard-drive-wd1003fzex
Why is one cheaper than the other?
WD's website said's they are exactly the same.
Is one a newer revision than the other?
http://www.wdc.com/en/products/products.aspx?id=760
Thanks for reading,
Antony :)
I read something about these drives some time ago
The "3" revision ( WD1003FZEX and others with 3 as last number ) have higher platter density, they are faster, more reliable and a bit quieter. The WD1003FZEX also has only one 1 TB platter, while the WD1002FAEX has 2 500GB platters. And less platters=better
I'd definitely get the WD1003FZEX
