what do you think?
nickfff
Thinking about ordering this PC from Build Your Box just seeing what you think i play games quite a bit
Processor:
AMD Phenom II X4 965 Black Edition @ 3.4GHz x 4 cores
Motherboard:
Asus M4A88T-M AMD 880G
RAM:
4GB Corsair XMS3 DDR3 1600MHz dual channel RAM
Graphics card:
Nvidia Geforce GTS 450 1GB
Hard drive:
1TB sata II 7200RPM hard drive
Optical drive:
DVD Rewriter
PSU:
500 watt PSU
Case:
Antec 300 Ultimate Gaming Case
OS:
Microsoft Windows 7 Home Premium 64 Bit
My lan PC is fairly close in specs to this (only difference is case and power supply really.) and it works well with most games, what resolution do you plan on playing and what games are you looking at playing?
Change the motherboard to a 880FX instead of 880G - would recommend a different gpu to the 450 GTS - 560 GTX / 6870? Also what brand is that 500watt psu it shouldn't be cheap or generic. TBH if you can build the pc yourself. Also what is your budget and how much would this cost you to order.
Yea the 450 isn't all that great. I would suggest to save that little bit more and grab a GTC460 768MB. That will give you much more performance.
