What CPU cooler
geb2
Hi have problems deciding what CPU cooler to use on my build. Have to down to 4
Phanteks black colour
Thermalright Silver Arrow SB-E
Alpenfohn K2 Mount Doom
Corsair H80
Before anyone said's it not the D14, just dislike the look of it. The case is a raven 3 so no H100. The CPU will be a over clocked 3570k not sure what to yet.
So what would you use?
NZXT Havik 140 or the Phanteks would be my picks if you don't like the D14. Btw the Phanteks is massive, it does fit in the RV03 but it's quite a tight fit due to it's size, but it's a beast of a cooler
Personally I would go for the Phanteks out of the options listed above but as has already been said it is huge. I would also recommend looking at the Be Quiet Dark Rock Pro 2, looks great and is very quiet.
I like the K2 Mount Doom myself (never used it just like how it looks), I currently use the Antec Khuler 920.
Stoner81.
