kenny01924
just want to know every bodys opinion which would you go for the cosmos ultra 2 or the Phanteks Enthoo Primo ,
1 quite agree with you therePhanteks gets my vote because the cosmos 2 cant fit a 60 mm thick radiator in the roof which is absurd for the price it costs.
well lads ive gone and done it getting a Enthoo Primo I should get it some time tomorrow looking forward to have a good look and a mess around with it a little. stroll on tomorrow
Update:
got it love it. like it. i would say buy it. very impressed.with it.
got it up and running beautifull case I would encourage every body to buy one its a pitty ttl couldn't get his hands on one very very nice
What's it like noise wise?
yes mate your right its a great case with a lot of cooling options the only thing that niddles me is the lighting they have used a female molex to plug in to your power supply ive got a corsair ax1200 watt which as only the female molex plug and sata id wished they use a sata on ive looked every were to see if I can get two male plugs one for the light the other for the power does any body know were I can get one from
