What Case
bobogib
i don't know if this has been asked before as I couldn't find anything.
Been advised by TTL that a triple rad would be best for the cooling I would like to do on my setup.
What I would like to know is..
What cases can happily accomodate a 360 rad internaly?
The only cases I can think of are
Coolermaster HAF932
Coolermaster Cosmos-s
are there any more?
TJ07, like 75%+ of all over £75 pound lian-lis, theres hundreds but lian li sounds like ur best choice
name='zak4994' said:
tj07.
'nuff said.
yessir +1
its ur best bet if u dont want to mod, heck even if u want to its the bast case on the market. for wc.. bad air flow tbh :nopitty;
if u can wait a bit WCUK marcus is working on a wc case that look stunning. i dont know how long its gona take untill they sell but hes contacting companies and getting a estimate on price soon.
ok then I take it the TJ07 is a good case,
Looked a the lian li cases and none of them are really what i'm looking for.
any others (maybe a little less than the silverstone)
honestly mate youll be lucky to find a cheap TJ-07 out there, no one seems to sell the on ebay, cosmos is probs ur best choice, or maybe a discontinued mountain mods case?? :rolleyes:
lian li v2010 bottom is HUGE, can fit phase cooling in there. but you do have to do a bit of modding which is cutting a vent for fans to suck air in and vent on other pannel for air to be pushed out. at £200 its £40 lesser than tj07 but the layout is kinda bad on the v20010.
bad:
1) motherboard against pannel so no power cable can be router around
2) no precut window or vents
3) notsure on v2010 but in v2000, if u cut a window it will be on the right side not left.
good:
1)HUGE bottom section easly fit 120.4 and a 120.3 in there.
2) £40 cheaper than tj07
3) big so easy to work with although some cable management thinking is needed.
name='Lynx' said:
But its an ugly ass case, and you can get a tj07 silver for £200 new from scan
o yea i always only loked at windowed version lol. no window tj07 £200. the v2010 isnt ugly... i like it
You could always get a Mountain Mods case. The ascension duality is designed for 3 PA120.3 (I would have put the link here for that case but i don't have enough posts so just google ascension duality first link) they hav smaller cases on there site just have a look around.
I have a lian li V2100 posted in my thread in the FS section (not a v2110) it is huge and is inverted ATX you can fit a lot of rads in there :D:D
