L louishudd New member Jul 30, 2012 #1 What is the best 8gb ram module for around £50 for asus maximus v formula
tinytomlogan The Guvnor Staff member Jul 30, 2012 #2 a single one....? To use on its own? I hope not :/
MadMarc Member Jul 30, 2012 #5 You can get a faster kit of 2x4GB for less money, why would you buy a single 8GB module?
MadMarc Member Jul 30, 2012 #8 I've heard of people having trouble upgrade the memory later, imo you'd be much better of buying now 2x8GB sticks (if you really need it) instead of adding more ram in the future. What do you use you rig for? Last edited: Jul 30, 2012
MadMarc Member Jul 30, 2012 #10 louishudd said: gaming Click to expand... Then there is absolutely no point in buying more than 8GB of ram
yassarikhan786 New member Jul 30, 2012 #11 As mentioned above, just buy 2 x 4 GB sticks. You can get most 8 GB 1600Mhz kits for less than £50.
J Josh Weston New member Jul 30, 2012 #12 ^+1 Just get some cheap 1600MHz modules with reasonable timings.
VengeanceUK New member Jul 30, 2012 #13 best off buying ram in pairs as even if you buy same brand same type of ram, compatibility is not guaranteed as not from same batch. buy either 2x4Gb or 2x8Gb and never buy singular sticks (IMO) as matching them later is nigh on impossible and you're asking for trouble
J Josh Weston New member Jul 30, 2012 #15 http://www.aria.co.uk/SuperSpecials...DDR3+SDRAM+CAS+9-9-9-24+1.5V+?productId=44336
