Weird Question, I know.
s.deng94
I am currently using a Corsair 600T case and it comes with two removable hard drive cages drive bays which holds up to three SSD's or HDD's in each cage. I have one SSD and one HDD in my tower atm. There are also four spaces on top of the case for optical drive bays.
I want to remove both hard drive cages to increase airflow from the front 200mm fan and mount the SSD and HDD into the optical bay drive. Anything out on the market for that right now? It will also help me with my cable management since I will be using one less PSU cable.
Thanks for reading and any insight will be greatly appreciated. :)
welcome to the forum,
you should have gotten a 3.5 to 5.25 adapter in your case kit. install the HDD in
the opti bay and mount the SSD with double-sided tape to the back of the
motherboard tray. one SATA DATA/power cable.. i use the molex to serial,
because the fan power is all molex. so one power strip for the drives and fans.
airdeano
