Just got hold of a new CPU cooler - NT07-115x, for reference - and it's behaving oddly.
I plugged it into the CPU fan header with the min. speed set at 12.5% in the BIOS (target temp <70 degrees), and the thing blows a gale - 2000+ rpm. I then tried it in the 4-pin SYSFAN header, and it works pretty much as it should. Indeed, in Speedfan I can put the speed wherever I want, and it stops below 30%. (One thing I did note, though, is that there is a very sharp increase in RPM over a small power interval - quiet at 60%, then RPM doubles at 65%.)
This issue does not affect my current heatsink; that one will sit at 700 RPM all day in the CPUFAN header. Any ideas? It's far too loud to run at "idle" as it is, but I would consider adding a discreet speed reducer.
