12V Laing DDC-1T Pro w/XSPC Delta Pump Top
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=77_74&products_id=615
XSPC X2O Delta CPU Waterblock
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=27_28&products_id=617
EK-FC8800 8800GTS - Acetal
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=27_78&products_id=672
Black Ice GT Stealth III
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=37_73&products_id=376
EK Multioption RES 400 Rev2
Artic Silver 5 - 3.5g
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=63&products_id=251
1/2" Clear/UV Blue High Flex Hose (XSPC) - (4m)
http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=38&products_id=647
Finally think I've picked my loop, note that the 8800gts block, I'm ASSUMING will attach to the 8800gt, i don t plan on buying this and then waiting to find out tho, the other way around in fact. I already have 3x 120mm 60CFM fans in my side door which I will swap for blue LED ones, and put the 60cfm ones in that rad.
I got a few problems though.
1. I think the CPU cooler is copper and the GPU block is aluminum, if someone can confirm this, is there any other CPU/GPU blocks I could use? I want to OC a quad so it has to be quite a good one for under £30 for CPU, or under £60 for the GPU.
2. Is everything there? As long as I select fittings for each individual thing, its all there right?
3. Is that rad enough to cool the whole thing? Ill probably add another GPU at a later date, hell I might even buy another when I get this. Is it still enough?
4. Is the pump strong enough to get the max cooling out of the rig?
5. Any possible improvements for the same or less money?
