WC Rebuild
How are you allowed so many pictures? I can only put 2 - 3 on mine before it exceeds my 500k global quota.
we use other image hosting sites (eases the bandwidth on the OC3D webserver)
i use http://imageshack.us/
it's free upto a limit
i resize, and then '30% jpeg', my images BEFORE uploading them. then i choose the option for them NOT to resize them. saves alot of space, so i can store more for free
the 1st and 2nd place rigs were triple-channel
i was the only one with dual-channel - and i still have mine !!!
AND, if mushkin only made one-offs for the comp - they lied
OR
bigian has painted them ????
All wrong
Tom had 2 heat syncs spare from the competition and very very kindly donated them towards my black and white WC build. Its the only 8GB kit in the world
TOM IS AN LEGEND!!!
All wrong
TOM IS AN LEGEND!!!
so it's not a real kit - just heatsinks put on other RAM ???
You should get one of them acrylic side panel windows from MNPCTECH to show it off
I have just got the Corsair 600T for my rig, as other case was getting bait tatty
It came with a side panel window, you just dont see all of the inside through it thats all
New 570 installed! I need to reorganise those PCIe cables though as they look a bit messy entering the gromet
Swapped with my old 560ti as im going to WC this baby soon
Looks great. Might I ask what case are you using? I think it's a Corsair(saw logo) 600T, correct me if I'm wrong tho. I don't recommend OC'ing the 570. The VRMs are under built, and fail before you run too much voltage through the GPU (Why I'm staying away from them).
Yeah its the white 60t
I dont really intend on OCing it tbb, the WC would be for silence under stress. Id much rather have a card thats cool and quiet at the same clocks than one that sounds like a hurricane when its doing something strenuous like folding
