Ok guys when i get my new rig up and running i want to watercool the gfx card but i have been looking around and the only waterblock i can find is the koolance one. What i need to know is what is the best waterblock?
-dangerden
-koolance
-alphacool
-ek waterblock
It will be used on a seperate loop due to my cpu going under a closed loop system (coolit freezone).
Any help would be appreciated, thanks.
P.s. if i go with the koolance shall i get the matching block for the voltage regulators???
			-dangerden
-koolance
-alphacool
-ek waterblock
	 Hope this helps. Also what size tubing are you going to be using as this would help narrow down the search?
