Highlander89
Hello!
I was wondering if there are waterblocks compatible with the Gainward GTX770 Phantom 4GB. I was first looking at the EVGA 2GB superclocked, but for 5€ more I would get the Phantom with 4GB.
I really like the looks on the Watercool Heatkiller and it would fit my color scheme in my upcoming rig.
On this link: http://gpu.watercool.de/WATERCOOL_HEATKILLER_GPU_Compatibility.pdf
At page 5 it says that the Phantom 4GB "Compatible waterblocks: 15521, 15520, 13105" and "PCB Layout: GTX 680 Reference".
What does this mean? And will the blocks fit?
Link waterblock: http://www.aquatuning.fi/product_info.php/language/en/info/p16003_Watercool-HEATKILLER--GPU-X--GTX-770--Hole-Edition--Ni-Bl.html
Backplate: http://www.aquatuning.fi/product_info.php/language/en/info/p15753_Watercool-HEATKILLER--GPU-Backplate-GTX-7X0.html
Thank you,
Highlander
Thank you,
Highlander
