I'm getting an evga 780ti through the evga step up program and the card they send you is the
EVGA GeForce GTX 780 Ti
Part Number: 03G-P4-2881-KR.
The waterblock and backplate I'm planning to get are:
XSPC Razor GTX Titan / 780 / 780 Ti Full Coverage VGA Block - Reference Design Part #: ex-blc-1592
http://www.xs-pc.com/waterblocks-gpu/razor-gtx-titan-780-780ti
XSPC Razor GTX Titan / 780 / 780 Ti / 770 Backplate Full Coverage VGA Backplate Part #: ex-blc-1432
http://www.xs-pc.com/waterblocks-gpu/razor-gtx-titan-780-backplate
I assume the waterblock and backplate will work fine on this card but I just thought I would ask to make sure.
Will these work without problems with the mentioned evga card?
