water newb asking for help
thecat666
socket 775
motherboard asrock penryn 1600sli-110db
cpu pentium 4 model number 630 3ghz 800mhz 2mb prescott
ram 667 ddr2 2gb x1
maxtor 250
graphics card nvidia geforce 7300 se/7200 gs
cooling artic pro 7. idle temp 42c load temp 52-53.
voltage, cpu-z says 1.464-1.496
voltage, vtt 1.375
voltage, dram 1.85
voltage chipset 1.250
overclocked to 3.9 at the moment,15 x 260
i all so have pentuim d 830 2.8gz 800mhz 2mb smithfield,and
pentuim 530 3ghz 800mhz 1mb prescott. im not sure wich one i
should be using for clocking so if any one has an idea please say.
1st do i have to have seperate Reservoir and pump or can i get a pump Reservoir,
eg XSPC Bay Pump Reservoir - Clear
parts list.
cpu blocks
CPU Waterblock OCZ Hydroflow HF-MK1 CPU Waterblock £29.07
cpu EK Supreme LT CPU Waterblock for Intel 775 & 1366 £35.99
radiator
Swiftech 1 x 120mm Radiator with Reservoir : MCR120-QP-RES £ 23.49
Swiftech 2 x 120mm Radiator with Reservoir : MCR220-QP-RES £ 39.99
can you also tell me what size make model pipes to use? fluid i should try
i know every one has their favourites so please say.
thanks for taking the time to offer any help and advice,thank you in advance.
i have joined a few other forums so i will be putting this on those as well,im
a proper newb to water cooling so if i ask a daft one please be gentle.
right lets have a go
1 - cpu choice - is it just for overclocking or are you going to use it day to day.
if its day to day then the dual core is what you want.
2 - pump if you want to run more than 1 radiator then you will need a better pump than the xspc ones, get a ddc pro pump with a xspc res top for it
3 - xspc delta 3 cpu block, best about imo
4 - radiator, get what fits your rig, if its just a cpu loop a 240mm rad will be fine but a 360 will help further upgrades
5 - 1/2 barbs and 7/16 hose is the best combo personaly
Coolant doesnt really matter feser or primochill ftw
cooling artic pro 7. idle temp 42c load temp 52-53. with the above kit will it be alot better than the temps i am getting? i would like to be as close to £120 including all bits and postage.i might be able to find a tad more change but not much more,thanks for the quick look.all post are thanked in advance and after
if its day to day then the dual core is what you want. yes overclocking and full daily use
