L LiamTheBoss New member May 9, 2012 #1 Hi guys, would someone mind telling which non refernce 7950 I can watercool? I have heard that the asus direct cu ii uses a reference pcb?
Master&Puppet New member May 9, 2012 #2 Put your gpu into here: http://www.coolingconfigurator.com/step1 It will tell you in the top right hand corner picture of the PCB whether you have a reference design or not
T TheOneHalf New member May 9, 2012 #3 Master&Puppet said: Put your gpu into here: http://www.coolingco...rator.com/step1 It will tell you in the top right hand corner picture of the PCB whether you have a reference design or not Click to expand... That is one awsome tool. I saw it actually lists the available waterblocks too or something, pretty cool.
Master&Puppet New member May 9, 2012 #4 Yea that site is written by EK to help people decide on blocks etc so it will only tell you which EK blocks fit but obviously if it says you have a reference pcb then any reference block will work on it.
KING_OF_SAND New member May 9, 2012 #5 A quick way. If it says "AMD" on top of the PCI It is 100% reference. If not, chances are it is not.
instinct_2k New member Jul 17, 2012 #6 Thanks for the info!!!! Looking at getting a Sapphire Radeon HD 7950 OC 3GB GDDR5 myself / but needed to make sure i could water cool it !!!
PEXON SleevingMaster Jul 17, 2012 #7 KING_OF_SAND said: A quick way. If it says "AMD" on top of the PCI It is 100% reference. If not, chances are it is not. Click to expand... That is not what he asked. OP, if you look on the EK Cooling Config, you will find a reference waterblock for the Asus 7950 DCII TOP Last edited: Jul 17, 2012
