T tigger New member Nov 23, 2015 #1 I am new to water cooling i was think about buy a ekwb EK-KIT X360 to start with does anybody none if i can replace the soft tubing with hard tubing in the future when i get more experienced in the art water cooling. Thanks for any help.
tinytomlogan The Guvnor Staff member Nov 23, 2015 #2 Yes you can dude but you will need to change the fittings from barbs to those that work with hardline. Other than that you will be fine
