Water Cooling - back to basics
Scoob
Active member
Hi,
As some of you know I’m a bit of a noob when it comes to water cooling. I’ve helped friends build water loops to their own specs, helping assemble blocks etc, but I’m yet to do a build for myself. With this in mind I have a couple of fairly basic questions, based on my observations:
Res location:
How can a system ever effectively bleed its self if the res isn’t at the highest point in the loop? I mean, air rises in water right? So surely we’d want the escape route for that air to be at the highest point. Isn’t there a danger with the res at the bottom that air will never find its way completely out of a top mounted rad say? This effectively reducing cooling performance of course.
How about bay res’s - which I like incidentally and one is on my list for WC parts. Even with the bay being higher up, a rad in the top of the case is higher still and so potentially a problem too? A particularly stubborn air-lock/bubble in a rad won’t be displaced without almost inverting the rig surely? Something that might prove somewhat tricky – my non-water-cooled case is pretty weighty as it is!
Filling a system for the first time:
Linked to the above, here’s a concern I have. WC Pumps are designed to pump water, not a surprise. However when filling a system with the res/pump at the bottom – like in one of Toms beginners videos – the system isn’t full of fluid when the pump starts first time. Now, we see in the vid that tom keeps the res topped up so the pump is never sucking air, which is good. However as the system isn’t full of water isn’t it likely that the pump doesn’t have to work so hard? I.e. it’s moving some water but mostly displacing air from elsewhere in the loop until the loop is near full.
With the pump not having to work quite so hard (less resistance) the impeller will surely spin faster, drawing more current for the given voltage rating of the pump – voltage that remains constant of course. Couldn’t too much current at this early stage potentially shorten the life of the pump in theory, or worst case cause it to go pop?
To me, again I remind you I’m new to this, it’s seems logical almost that you’d want your res or res/pump combo to be at the highest point in the loop to allow air to bleed more naturally. Being at the highest point would aid initial filling and having a near-full loop (just letting gravity do its thing) before turning the pump on the first time would be very pump-friendly.
Now, like anyone, I’d like to build a loop that is both effective at cooling and looks neat and tidy. How much is res/pump placement anywhere other than the very top of the case a compromise regards effectiveness overall? Also, how much trouble can it potentially be filling and getting air out when the res is elsewhere?
One more time, to hopefully prevent any flaming, I’m NEW to watercooling and these are things that are on my mind. I’ve seen lots of fantastic builds on this site that seem to totally negate what I (as a noob remember) would consider sensible rules to avoid possible issues.
So, my question, why aren’t the points I’ve raised considered much of an issue? I have some theories of my own but would rather not second-guess anything at this time. I’m here to learn, so if some of what I’ve assumed or been pondering is rubbish then I’d like to know – though I’d also like to know why
I want to build my loops right and sometimes there is so much conflicting information out there!
Cheers,
Scoob.
These points also give concern to me too, I've never watercooled a loop but I guess I know the basics. Im 85% sure I'm going to be watercooling my new rig so I hope someone can give us some insight soon.
The way I see it is if it's the way the pros do it and they don't have probs i'm sure we wont. To be honest I don't think any of it really matters, once the loop is up and running air bubbles will eventually go away and pump will be running at full efficiency.
As long as you follow what Tom says or what ever other tips you find from other people everything will be ok.
basically ur correct but if you wiggle the system around a bit while the pump is running eventually you will get water pushing the air to the rez and since the rez is where ya can burp the air out from then you will get it all out. swince the barbs on a rez are normally at the lower point the air goes into the empty space and whallah
Hi,
Thanks for the replies.
So basically what people are saying is that my observation re: Res location is right, but a bit of wiggling usually sorts it? Really that simple eh? I mean, we hope that rad design internally means that there are no pockets that could trap air overly easily (design flaws if you will), so the water pressure should eventually force the air out.
Ok that's cool, how about initial running of the pump where there's not quite enough resitance? I guess as long as you keep topping it up it's really not considered an issue then?
Other sources of information on the internet (I know, I know! lol) would actually want to crucify me for suggesting any of the above you know! However if this approach is working, giving good systems that cool well, look good and aren't failing or running hotter than expecting (something you often read about that one) then I guess all is well.
I'm going to build my loop how I see fit, basically with a bay res and topping it up as I run the pump (which was my plan anyway) and see how I go.
Cool, well if anyone reading this has more to add I'd welcome your views.
Cheers,
Scoob.
