Mgutierrez33
Hey all. Just made a significant purchase for my rig that finally, in my opinion, made it worth posting up here.
I named this machine "War and Peace." The reason for this is because everything that has happened with this computer since it's initial build has been an uphill battle... but when I DO finally get everything sorted, there is usually a long period of time where nothing goes wrong and everything is buttery smooth. It will most likely always be a work in progress, as the OCD in me will not allow me to rest until it is perfect... and once more hardware/mods are released/thought of, it's no longer perfect and needs to be improved upon x-).
System Specs:
Corsair Graphite 600T (Gunmetal)
Silverstone Braided Cable Extensions
Asus Sabertooth 990FX R2.0
AMD FX-8350 @ 4.4 Ghz (1.36V)
Corsair Vengeance LP 1600 Mhz memory (2x4GB @ 2133 Mhz)
EVGA GTX 560 SC 2GB (930 Mhz core, 2200 Mhz effective memory)
Corsair H100i w/SP120 Quiet Edition fans
AF 120 Quiet Edition rear intake
Crucial M4 128GB SSD
Seagate Barracuda 1TB HDD
OCz 500W Semi Modular PSU (I NEED to ditch this as soon as funds allow for it)
Some glamour shots with the side panel on.
Plans for this rig include placing a priority on replacing the GPU, as it is now getting long in the teeth, the PSU because it's garbage, and finally getting a custom waterloop done. When the times comes for the watercooling bit I will start up a proper build log, but as of right now funding is pretty tight and I was barely able to afford the motherboard at this juncture. Ultimately, the goal is to mount a 360mm rad in the roof cavity (need a rad with a split end tank where the barbs mount to do this) and a 200mm rad in the front. This SHOULD be enough to incorporate the CPU and two GPUs before I run into issues with temps.
Notice I didn't take any shots of the cable management. This is because by my standards it's trash, and it will be getting redone as soon as I can afford a PSU anyway, so not really a need to "show it off" or "ask for advice" on it just yet x-). Otherwise, thar she be... me mighty vessel! Hope to see you all throughout the forums!
:beerchug:
System Specs:
:beerchug:
