well im after some advice as to if its normal for the idle v core to be higher than when its under load
ive not noticed this before but since i have put the motherboard settings back to stock (so cpu is now running 3.3GHz again) i have since noticed while checking the temps that the v core on idle is higher than when its under load
cpu is a intel i5 2500k
v core at idle: - 1.236v
v core under load: - 1.164 to 1.176v
