Visual basic on Ubuntu
mrapoc
I want to use my laptop as a 100% Ubuntu (no dual boot). I d
only have one license for Eset so i cant really defend it (AVG etc. is just meh) and now my sister has started using it - its even more succeptible to crap like that.
All i use my laptop for is browsing, random games on the train, typing up crap and programming. What would be the best bet for visual basic/express on my laptop? Wine?
Yes for WINE. Kickass program that works with damn near everything. Hell if I can make CSS run natively in OS X with it I'm sure you can get VB to work in Linux with it. :)
I personally wouldn't code using wine.
Quite a few reasons really, the main one being stability and the posibility of data corruption when testing code.
Wine isn't a enclosed emulation/virtualization of windows. It is just a compatibility layer which runs in conjunction with the linux OS. So I would think that things like memory leaks etc could possibly be pretty hazerdous to your linux system and most importantly your data.
name='winehq.com' said:
Think of Wine as a compatibility layer for running Windows programs. Wine does not require Microsoft Windows, as it is a completely free alternative implementation of the Windows API consisting of 100% non-Microsoft code, however Wine can optionally use native Windows DLLs if they are available
I sometimes code using Parallels in OS X just because it is enclosed to itself. I used to use VMWare on linux to code/test some windows stuff aswell. Mainly cross-platform networking stuff.
personally i would prob do the following if you want to use linux as your main os.
Install vmware, then create a new virtual os with windows and use that for programming.
ahh right, couldnt get WINE to work on the .exe installer anyway, tried to use unshield etc. but im n00b. Sounds like a grand idea. How does it work?
