Vista/Photoshop/Tablet Issue! help.
ScottY_
No idea where to put this so it's in here.
Photoshop freezes, Black screen flash, BSOD flash, reboots
It appears to be happening with my tablet in Photoshop.
Photoshop either freezes, crashes or the screen just flashes up a BSOD, in milliseconds so i have NO chance of reading it, and then the PC reboots. Any one know a way of finding what that BSOD says that would help.
I ran a virus check, nothing, i ran spybot and cleaned all the crap it found. Did it again.
So i un-installed my tablet drivers, and re-installed them from Wacom's site.
Same thing happens with ym tablet, yet if i use my MOUSE to paint with it's fine, i go to use the tablet and it does it again, my tablet/vista/drivers have an issue and i need help.
Seriously Vista is a
, might get SP1 and see if that fixes any of the problems i get, if not ill send a e-mail to M$ tell em to get their fingers out from where the sun don't shine and sort it out :P I payed good hard cash for this and it's, useless.
First off, as most people dont seem to get. How do you know its a vista problem? It could be related to lots of other things that are not related to microsoft. (drivers, 3rd party software).
anyways, Have a peek in the even viewer. Usually some useful info in there.
I never said it was Vista specific, but i have had some damn annoying issues with Vista, so i moan about it. :)
I have used it for roughly 1 month on the same system with the same drivers yet now it screws up...
Im going to boot my laptop running XP up and see if that works on CS3 under XP. If it does good ill finish my piece then spend all of xmas trying to sort it out even if i have to do a full re-install of vista.
Ill have a look in the event viewer cheers for that.
