Duality92
ver′ti·cal′i·ty
[vur-ti-kuh l]
adjective
1.
being in a position or direction perpendicular to the plane of the horizon; upright; plumb.
2.
of, relating to, or situated at the vertex.
3.
of or relating to the cranial vertex.
4.
Botany.
(of a leaf) having the blade in a perpendicular plane, so that neither of the surfaces can be called upper or lower.
being in the same direction as the axis; lengthwise.
5.
of, constituting, or resulting in vertical combination.
6.
of or relating to a product or service from initial planning to sale.
7.
of, relating to, or noting a stratified society, nation, etc.
noun
8.
something vertical, as a line or plane.
9.
a vertical or upright position.
10.
a vertical structural member in a truss."
Parts List
Hardware
AMD A10-7890K
Gigabyte GA-F2A88XN-WIFI
G.Skill Trident X 2*8GB 2400/10
G.Skill SSD
HDPlex 160W DC-ATX
HDPlex 160W AC-DC w/PFC
Cooling
1 * Alphacool XT45 280
2 * Be Quiet! Silent Wings 3 PWM 140mm fans
1 * Alphacool DC-LT 2400 Ceramic Pump
1 * Alphacool DC-LT Pump Top | Plexi
4 * Alphacool Eiszapfen G1/4" 45° Angled Rotatable Adapter Fitting - Black
4 * Alphacool Eiszapfen G1/4" 90° Rotary L-Connector - Black
2 * Alphacool G1/4 16mm Knurled HardTube Compression Fitting - Black
1 * Alphacool G1/4 Bulkhead Connector - Black
1 * Alphacool G1/4 Round TEE Connection Terminal - Black
1 * Alphacool HardTube 16/13mm Plexi Clear 40cm
1 * Alphacool NexXxoS XP³ Light - Acetal - Intel/AMD
8 * 8mm / 11mm Compression Fittings
Modding
75 * Darkside 2mm (5/64") High Density Cable Sleeving - Graphite (DS-HD2-GMC)
25 * Darkside 2mm (5/64") High Density Cable Sleeving - Opaque Red (DS-0731)
2 * Darkside 7.75" (20cm) Dimmable Rigid RGB LED Strip (DS-0533)
1 * Darkside Custom Configurable Colour, Dual RGB LED Controller with Remote (DS-0535)
4 * MMM 18 AWG Ul1007 Hookup Wire 25' - Black (MOD-0147)
1 * MMM 24-Pin ATX Female Connector - Black (MOD-0096)
1 * MMM 24-Pin ATX Male Connector - Black (MOD-0095)
1 * MMM 4-Pin EPS Female Connector - Black (MOD-0105)
1 * MMM 4-Pin EPS Male Connector - Black (MOD-0104)
1 * MMM 5-Pin SATA Female Connector - Black (MOD-0106)
20 * MMM ATX Female Pin - 5 Pack (MOD-0116)
2 * MMM SATA Pin - 5 Pack (MOD-0117)
5 feet ModMyMods 8mm ID x 11mm OD PVC Tubing - Clear (58000)
1 * SIJIAWU Professional Wire Stripper and Cutter - 16 to 26 AWG (DY-011105)
1 * UPC Custom Pin Crimper (UPC-0001)
3D Printed Parts
Motherboard, SSD and cable management bracket
Pump and Power Supply mounting bracket
Reservoir top and bottom
Base stand
Motherboard pin covers
Input cable management
Fan grills
