domsch1988
Hey guys.
I've not posted in some time. Back then you all helped me out well, with getting my current setup together. I used parts from friends, used parts and new parts to put together a rig that served me well till now.
Current specs:
Asrock 890gx extreme3
Phenom ii x4 955 be
Asus GTX570 dcii
H80 i
Corsair CX600
8GB Ram
120GB HyperX 3k SSD
1.5 TB Green Drive
As said, this system served me well till now. Right now the motherboard is passing. USB3 stoped working and USB2 work sometimes
So i have to replace it. There are no resonably priced AM3 boards available, so i thought "upgrading" to intel would be my way to go.
Luckily enough i could get a Gigabyte GA-Q77M-D2H from ebay for cheap (new). I chose this because of OS X compatibility and price.
Most of my rig will stay. I'll get a Bitfenix phenom M when it's available. My PSU, Graphics, HDD's, CPU Cooler will stay.
Now i need a matching CPU. I use it 80% for Browsing, listening to music and watching movies. So things a low end celeron would handle ^^ 20% is Gaming. Currently only Rocksmith and some occasional batman Arkham City. The Performance of my current rig is sufficient, so as long as i match the x4 955 or surpass it i'm happy.
And did i mention i'm tight on budget (As always
Soo, my current thought was i3 3220. This is available for under 100€ and seems to perform better than my current cpu.
Some questions: Will this in any way bottleneck my gpu? Is there a cpu which is worth spending a few bucks more (remember that the 1155 board is on it's way. So no Haswell for me)? I don't need integrated graphics, if this matters. Is there anything else you'd recommend upgrading from my rig?
Thanks for reading this long post and thanks in advance for any suggestions provided.
Rock on
Dominik
Current specs:
Phenom ii x4 955 be
Asus GTX570 dcii
H80 i
Corsair CX600
8GB Ram
120GB HyperX 3k SSD
1.5 TB Green Drive
Rock on
Dominik
