Hey all i'm new to the forum
I come here to ask for some advice.
First my current build is:
Corsair TX-650W V2
Asus P8P67 REV 3.0
i5 2500k @4.5GHz (1.31v)
Gskill RipJaws X 4Gb 1600MHz
Sapphire HD6870 @stock
My doubt is i'm planing on buying another GPU and make crossfire.
I don't whether to buy another HD6870 or an HD6870 X2 (i consider the second one because i've seen reviews that state that a crossfire between a X2 and a normal completely removes the micro stuttering effect...)
Independently of the one i buy i'll have to change my mobo (P67 sabertooth?) and my PSU (an 750w for 2 Hd6870 or an 1000w+ for X2 and normal)...
I have 3 questions.
First should i even consider crossfire? If crossfire is ok, which one of the builds do you guys think is best?
Or i should forget crossfire i just buy a nice single gpu (either nvidia or amd)?
Thanks in advance
Corsair TX-650W V2
Asus P8P67 REV 3.0
I have 3 questions.
Thanks in advance
